Go Back   Automotive Forums Car Chat > Buick > Rendezvous
Old 06-21-2009, 11:50 AM
racedad21's Avatar
racedad21 racedad21 is offline
Unhappy Rendezvous blower just stopped..resistor? Help..which fuse?
Need some help here guys. Wife's '02 Rendezvous blower fan just quit while driving. Could it be the resistor? Problem is all the threads say the resistor will only affect some of the fan speeds, and not all.
I don't have a manual so I have no idea what fuse it could be in the console.
Any help would be appreciated. Thanks.
Old 06-21-2009, 02:26 PM
racedad21's Avatar
Re: Rendezvous blower just stopped..resistor? Help..which fuse?
anyone?
Old 06-23-2009, 10:45 PM
racedad21's Avatar
Well I guess I'm on my own with this one.
I pulled the fan out and bench tested it, it worked perfect. I tested the prong and it looks like I have power to it. So why is it not working? Could it infact be the resistor? I'm not even sure where that little sucker is. Could it be the little box inside the fan housing with wires going to it? Help...
Old 06-29-2009, 06:19 PM
racedad21's Avatar
So what good is this forum anyways?
Nothing like asking questions and getting no response.
I guess I should be building a model or something.
Old 06-29-2009, 07:50 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
You may have a blower control module that failed rather than individual resistors, it depends on the system; and yes, if it has a control module, it is the "little box located in the fan housing". No solution other than replacement.
Old 06-29-2009, 08:40 PM
racedad21's Avatar
Thanks alot for the reply!!
This blower control module you speak of, would this just be another term for a resistor? Or would I have both. I have the dual zone climate control system and I've read that they don't have a resistor with coils like most vehicles. Am I making any sense?
Mine has a piece of finned aluminum with a circuit board attached.
Thanks again.
Old 06-29-2009, 10:13 PM
HotZ28's Avatar
AF Moderator Elite
Does the module you have look like the one below? If so, it is the only blower speed control you have and it is better known as a "self-contained resistor module".
Old 06-29-2009, 11:20 PM
racedad21's Avatar
Yup, that's the one. When I test it, I have contenuaty (sp?) on 2 of the 4 prongs if that makes sense. I'm gonna see if the local GM dealer has a new one I can test before buying one. I'm hoping it's my problem.
Thanks for taking the time to help me out.
Old 06-30-2009, 06:28 AM
HotZ28's Avatar
AF Moderator Elite
Check ebay; do a search for "Buick blower control module". You can usually find one for 1/2 the dealer cost.
Old 06-30-2009, 06:36 PM
racedad21's Avatar
Great news. Fixed. Thanks alot for all your help Hot Z28!!
Local dealers wanted $194 bucks for a new module. I just pulled it apart and resoldered the board. Cost...$0.00 nice. Took a bunch of time getting it all figured out though.
Untill next time.
Old 06-30-2009, 08:35 PM
HotZ28's Avatar
AF Moderator Elite
Thanks for the feedback, I have repaired a few on my own cars the same way, but normally replace them for customers! Good news and great troubleshooting!
Old 07-07-2009, 11:35 AM
msull msull is offline
read about your problem i have similar problem i bought new fan module for 30.00 i just need to know the location and how difficult is to get to
Old 07-07-2009, 06:56 PM
racedad21's Avatar
I'm sure it's in the same location as mine. Passenger side under the glove box, pull the plastic cover off and you will see the blower. 3 screws and the blower is out, then just behind it you will see the resistor. Another 3 screws and it's out also.
Be sure you bought the right part because they make different resistors for the different climate control options.
Just ask if ya need more help.
Old 08-06-2011, 08:12 PM
Rendy Rendy is offline
I did the same(Resoldering a board) work perfect, as mentioned above
