Go Back   Automotive Forums Car Chat > Chevrolet > Aveo
Old 06-21-2009, 08:38 AM
kaos95 kaos95 is offline
Removal of cylinder head
Does anyone have a good resource online on how to remove the cylinder head of a 2004 Chevy Aveo? The timing belt stripped out taking out 1 or more valves (can't tell how many until I get the stupid head off). I can get a rebuilt head from the local napa for not too much (way less than a new engine) and if I can take it apart I can put it back together.
My big problem here is that I have a lot of experience with chevy 350s but have never worked with or around anything this . . . small.
The real question that I am having at this point is if I remove the head with the intake manifold still on, and if so how to remove the EFI from on top of it, because I can not for the life of me figure out how to remove the lower intake manifold bolts.
Any help would be great thank you (and yes I know the car isn't worth it, but I am currently driving an 1984 GMC Sierra . . . with a 350 in it . . . 8 miles a gallon X 20 gallon gas tank, so seems to be worth it to me just as a commuter car)
Old 06-22-2009, 02:19 AM
Davescort97 Davescort97 is offline
Escort guy
Re: Removal of cylinder head
Welcome to AF!
If you go to www.autozone.com they have repair information for the Aveo. It tells what to do to remove the head and the intake and the EFI. btw, how many miles were on the engine when this happened? I have an 05 pushing 70,000 miles and have never changed the belt. ~Dave~
Old 06-22-2009, 07:59 PM
Had 72k miles on it when the teeth stripped out of the timing belt. Autozone is decent for general info, but I happen to be a very visual person (think pictures)
Anyways, I am slowly figuring it out, and am taking pictures of eveything . . . so when I finally figure it out I will most likely be posting a nice guide with pictures of every nut bolt and connector.
Old 06-23-2009, 08:03 AM
Escort guy
Thanks for the mileage info. I'd best change my belt ASAP. Autozone lists mostly what to do rather than how to do it and yes, the pictures would help a lot. A picture's worth a thousand...... If you keep in touch and let us know how it goes with pic's you'll be helping a whole lot of people that have the same problem. So, thanks in advance for that. We appreciate it.
Old 06-24-2009, 07:26 PM
toni1595 toni1595 is offline
It's too bad, my All Data for this car just ran out June 21st. I picked it up so I could change the timing belt, which by the way Dave is "supposed" to be done every 60K, so I would definitely get it done soon as this is an interference engine.
You could get your own subscription. I think it's $29.95 for the first vehicle, then they lower it to $16.95 for any others and also for a renew. The only thing I have against it is, it doesn't have ALL of the information. Although it does a pretty good job. I don't think the car company(GM), gives it all away, or whatever kind of a deal they make with them.
Anyway, I hope this helps some, Toni.
Old 06-27-2009, 06:49 AM
Hehe, well I think I am almost there, and I took a ton of pictures so I could get the stupid thing back together . . . and just for general info, if you wanna take off the head you are going to be disassembling half the engine from the top down . . . super fun
Old 06-27-2009, 02:03 PM
Escort guy
Thanks for the update. Hope everything goes well. You'll have no trouble with it.
Old 06-27-2009, 02:59 PM
Hehe, no trouble my . . . the stupid thing is now diconnected from the block, yet still won't come out . . . taking out the AC system now . . . sigh . . .
Old 06-27-2009, 08:10 PM
Escort guy
Hang in there. When you get time could you run through all that you had to do to pull the head. Sounds like it's being a real PITA. Think of all the labor you are saving if you took it to the dealer. Hope you don't have a hole in a piston. That would be the berries.
Old 12-30-2010, 04:49 PM
AngryJonny AngryJonny is offline
Hey,
A friend of mine just had the same problem, timing belt went, and presumably there is internal damage to valves and possibly cylinders. I'm hoping to help her out a little and figure I can at least remove the head and survey the damage. Of course the shop wants way more than the job is worth (I think.....). Came across this thread, and hoped that maybe some of those photos might still be around, or at least advice on whether or not this is a worthwhile undertaking. I'm loath to let the shop do, and especially on an engine this size, I figure its a one man job...
Any advice? I realize this is an older thread, but I hope the bump might be worth it.
Thanks in advance.
Jonny
Old 12-31-2010, 09:21 AM
Hey Jonny, there is a website that I found that was quite helpful. I'm not sure that I can post it on here though.
This motor is actually a Daewoo {Korean} and not manufactured by GM. Turns out that the Daewoo had or has a car with the same engine, I think it was a Lanos or maybe a Kalos.
Anyways, if you want the name of the site, let me know and I'll either post it here or send it to the email address of your choice.
Toni.
Old 01-01-2011, 10:56 AM
Hey thanks!
Yeah, that website might be really useful. I don't know entirely what she intends to do with the car, but again, if I can help save a couple hundred dollars, then great.
Send the link to [email protected]
I appreciate it. Didn't know if such an old thread would get resurrected with any success.
Jonny
Old 05-11-2011, 10:03 AM
Shanooby Shanooby is offline
My Aveo's timing belt idler pulley broke while driving 55 MPH. I replaced the tensioner , water pump, idler pulley, serpentine belt , and timing belt. Tried to start the car and have no compression. I see that there isn't any updates to this thread so, I'm going to create a guide with video and pics on how to remove the head and fix the bent valves. If your interested send me an email. BTW.. so far this is what I've spent on this repair.
$65 towing car to my driveway
$132.95 (timing belt, serpentine belt, water pump) at autozone
$93 (tension pulley and idler pulley) Chevy dealer
$25 new spark plugs and hose clamp
$50 for a Husky socket set metric / standard
[email protected]
Old 05-15-2011, 06:31 PM
laflega laflega is offline
I have a PDF file of the whole engine and it will walk you through the steps. I was able to take the head out in just about three hours. All 16 valves were shot. I am sending the head to the machine shop and I should be able to have the whole thing reinstalled with a new timing belt, water pump, tensioner and idler in about another 3 to 4 hours. Aprox total costs of $700. Unfortunately the file is too big to upload. It is 2.8 MG. How can I upload this file or pass it on if somebody is interested.
Old 07-27-2011, 09:55 AM
jrr4948 jrr4948 is offline
laflega- Can you send me the PDF file to remove the head on an Aveo?
[email protected]
I need to replace mine. Dealer just quoted me $1600 P&L!!!!
I saw a rebuilt one online for $575
Thanks
