Old 06-19-2009, 06:32 PM
khamptonkh khamptonkh is offline
P0440 Evap system problem
Hello all, this is my first post, I'll try to give you all available information.
So, I have a 2001 cavalier. 2.2
The check engine light came on and the code it spit was P0440.
From what I have read this could be anything in the evap system ranging from a poor seal on the gas cap to the exaust system.
I have replaced the gas cap with no luck.
I am also getting very loud hellicopter like sounds, especially when accelerating from stop. Do you think that this is at all related?
Old 06-20-2009, 11:59 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: P0440 Evap system problem
P0440, take a quick look for broken EVAP hoses. If you don't see any, take it to a shop that has a diagnostic smoke machine. You're not going to find it without one.
For the noise, quite possibly the exhaust flex joint has partially broken and is making an exhaust leak. Check for a broken motor mount, too much engine flexing will break them.
The two could be related if an evap line is also broken where it flexes.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 06-21-2009, 10:08 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
EVAP problems are a mo fuggin beeotch. My sunfire gets a P0445 during the winter then goes away in the summer. EVAP leak large... no idea where it is, nor do I care until it prevents me from passing inspection because it doesn't really hurt the car.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
