Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 06-18-2009, 02:47 PM
chad1971 chad1971 is offline
2000 Civic power door lock won't unlock.
I have a 2000 civic DX-V and the keyless entry will lock and unlock the doors. The doorlock switch on the drivers door will lock all the doors but it will NOT unlock any doors. I replaced the switch and I have the same issue. Any Ideas??? Thanks in advance for the help!!!
Old 06-18-2009, 05:45 PM
Copytech99 Copytech99 is offline
Re: 2000 Civic power door lock won't unlock.
You could have a broken wire in the drivers door loom wiring (most likely at the flex point between door jamb and body) If you can locate the wiring at the drivers kick panel you could try grounding it and see if the unlock works. You will need to research for the correct wire color.
Old 06-18-2009, 06:52 PM
I will try that... Thank you!!!
Old 06-19-2009, 07:17 AM
I had the 96-00 factory manual on CD and for the life of me I cannot locate it. You should be able to find it on the web for free ( I did ) it will help with the wire colors. The wiring used is very thin.
Old 06-19-2009, 08:56 AM
Cool. Thank you! I will look for it on the web...
