Go Back   Automotive Forums Car Chat > Cadillac > Seville
Old 06-18-2009, 01:27 PM
abcfg abcfg is offline
76 seville engine
were any 76 Sevilles made with fuel injected Pontiac 350 engines? My brother is convinced that the engine in his Seville is a pontiac block, the same as his 400, But from what I found they only had oldsmobiles.
Old 06-18-2009, 02:06 PM
maxwedge maxwedge is offline
A990 racer
Re: 76 seville engine
Absolutely not, they were all 350 Olds blocks with primative Bosch fuel injection, or later on they converted the 350 Olds to diesel which was a disaster.
Old 06-18-2009, 06:53 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Oddly enough, for the diesel Cadillac era, the diesel 350 was the 'standard' engine, the gasoline engine was the option...... which, of course, goes against common car marketing tactics.
Old 06-19-2009, 07:02 PM
He is still convinced that it is a fuel injected pontiac 350 with a spider intake. I think he is . I can't convince him otherwise. Although, it could have been put in there. Who knows.
Old 06-19-2009, 07:26 PM
A990 racer
Tell him to google those Sevilles all the factory info is out there, I was a field trouble shooter for Cadillac back then, no Pontiac engines for sure.
Old 01-29-2010, 02:01 PM
CRBBASHR CRBBASHR is offline
gonna attach a tail to this post instead of starting my own-76 seville 350 OLDS motor, just my transpo at the moment, looking for some experienced help here; running real crappy-done cap/rotor/a-filter/plugs/wires.thinking fuel filter (can't find it yet) or something that decided to take a dump at the same time as when i did this stuff and run worse.@#$$%%^$#^& appreciate any help.i bought this 76 seville becuase it has a 350 olds motor-for a reason, but i'm missing something.
Old 01-30-2010, 09:53 AM
A990 racer
There is no way to diagnose this accurately on the net, , low fuel pressure, bad dist sensor/gov allowing only 4 cylinders to fire, you need to determine whether all 8 injectors are firing. You need a shop manual to get into this. Make sure you have vacuum to the map sensor at the port on the ecu under the center dash also.
Old 02-01-2010, 07:29 PM
thanks for the leads-this may end up being outside my capabilities.
