Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 06-17-2009, 10:29 PM
85mustangGT 85mustangGT is offline
Blinkers turn off Daytime driving lights
Just noticed this the other day while I was driving behind a gas truck and could see the reflection of my beautiful 1999 Bravada, when I put on the turn signals (either left or right) my day time driving light would go out and remain off until the blinker was turned off. Is this normal or not? First time I have noticed it.
At night when the headlights are turned on, they remain on - that would be real bad if they went off every time I turned on the signals.
Old 06-17-2009, 11:07 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Re: Blinkers turn off Daytime driving lights
Yes this is normal. The DRLs go off when your turn signal goes on so that the turn signal will be more noticable.
Old 06-17-2009, 11:15 PM
Thanks for the fast answer, I can't believe that I have not noticed it before now. After all these years you think you would know your vehicle and then SMACK - something new...
Old 06-18-2009, 05:58 PM
ericn1300's Avatar
AF Premium User
It also has the anoting side affect that some drivers will think you're flashing them. The DRL bulbs can be safely removed if it's annoying you, the head lamps are seperate
Old 06-19-2009, 05:23 PM
97TaurusGuy's Avatar
97TaurusGuy 97TaurusGuy is offline
Send a message via AIM to 97TaurusGuy
Pretty certain the daytime running lights run off the high beam bulbs at about 80% power. Never heard of them having a seperate bulb nor can I find a seperate bulb for it.
"Save water, shower with a friend"
