Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 06-17-2009, 05:53 PM
sixwongs sixwongs is offline
1998 Saturn SL2 no start
Did not start for 3 days.
just would not catch.
tried spraying carb cleaner to see if it would start a little that didn't work.
tried cranking with pedal down almost started.
check air cleaner, regaped plugs,
Found filter paper a little chewed up, set a mouse trap in garage.
Found one of the spark plug boots had oil surrounding it ,cleaned that up.
Tried starting almost caught, cranked with pedal down. after a bunch of
tries finally caught.
could it be fuel filter needs to be replaced ?
Is there one on the car?
Not sure why it happened to start this time
any ideas?
thanks
Old 06-17-2009, 08:49 PM
Cat Fuzz Cat Fuzz is offline
Re: 1998 Saturn SL2 no start
Maybe a leaky fuel injector or three? Hook up a fuel pressure gauge and see if it bleed down rapidly. Pull the spark plugs and check for fuel puddles on top of the pistons.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 06-17-2009, 09:32 PM
saturntech's Avatar
saturntech saturntech is offline
Start by replacing your coolant temp sensor
Old 06-17-2009, 10:36 PM
RC1488 RC1488 is offline
+1. Bad ECTS. A cracked ECTS will flood the engine. By holding down the pedal to the floor it shuts off the injectors when cranking to clear the extra gas. I posted a video for this on here before.
'98 has a fuel filter good for 100k. Not the issue.
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
