Old 06-17-2009, 01:18 PM
popppins popppins is offline
Angry A/c help
2001 Honda Civic mileage: 75,000. My A/C works fine first time you turn it on. Runs for 10 min then stops cooling & THE FAN STILL WORK
THANK YOU
Old 06-18-2009, 12:47 AM
pbrizzle86 pbrizzle86 is offline
Send a message via AIM to pbrizzle86
Re: A/c help
you sir are on the wrong forum.... but anyhow it could be a number of things, the compressor could be making to much pressure or not enough pressure, and it stops working. there could be a restriction somewhere, you need to get a set of pressure gauges on there and see what its doin while the problem is occuring, or take it somewhere, dont know much else to say, is it very cold while it works? when the problem is occuring you can look at the ac compressor and see if the clutch is spining with the pulley assembly to see if the compressor is on. unless you know what your doing and have some of the basic tools you need for a/c work, it can be a pain
Current cars
1990 honda civic dx High Comp mini me
1986 HONDA CRX SI
Need a winter mobile....
