Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Non-Performance
Non-Performance This is the place to discuss interior, exterior, and other non-performance related modifications.
Old 06-16-2009, 09:56 PM
Shelby<3'scavvy's Avatar
Shelby<3'scavvy Shelby<3'scavvy is offline
Send a message via AIM to Shelby<3'scavvy Send a message via MSN to Shelby<3'scavvy Send a message via Yahoo to Shelby<3'scavvy
steering wheel help
I want to replace my wheel with another one of the same. can someone please explain howto do this. esp concerning the airbags. i have searched and not found anything so sorry if i missed it
98 chevy cavalier RS. i'm workin on it... <br/ >
95 chevy cavalier... totaled. parts!!
Old 06-17-2009, 05:47 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: steering wheel help
Never done one on a Cavalier, but every GM I've seen is done like this:
Disconnect the battery, record your lock code, if applicable. Connect both cable ends together with a jumper wire to prevent any static electricity buildup. Remove the screws from the back side of the steering wheel. Some are 1/4 or 1/2 turn fasteners, but not very many. If they stop turning or don't come out, this would be why. The air bag should now pull off enough to remove the electrical connector. Remove the nut from the shaft. There may also be a wave washer, I don't remember for sure. Once the nut and anything else is off, the steering wheel should pull off. You may need to tap the shaft a bit while pulling on the steering wheel. Don't hit it hard, the steering shaft is collapsable to keep it from impaling you in a crash. Hitting it hard will break the plastic rivet-ish thing that holds it solid. I'd reuse your airbag, you never know about the one you may have got if one came with the steering wheel. Unless it's new, but I'm assuming used.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 06-17-2009, 06:22 PM
rhandwor rhandwor is offline
I always use a steering wheel puller. Look at ling and run the other numbers.
Auto Zone or Advanced Auto have a tool loaner program.
http://www.autopart.com/tools/toolsmain/tool/T_1515.htm
Look at 1500,1512,1520 Use search.
Old 06-17-2009, 08:32 PM
mm thnks =] ok i am using a wheel from my old car that ive had for 2 years... and had one owner before that, and i know her. so i should be good right>> just do that in reverse order to put the other one on?
Old 06-18-2009, 03:20 PM
J-Ri's Avatar
Steering wheel puller? Where's your sense of adventure? It is a good idea to at least have access to one, but most steering wheels I've done just about fall off once the nut's removed.
You got it, install is reverse of removal... probably with a torque spec, but "tight" hasn't come back to bite me in the ass yet. One thing I forgot to say, make sure the shaft and wheel are "dummy splined", where it will only go on one way (most are). If not, you need to mark it with a chisel so the wheel is straight after you put it back on.
Old 06-18-2009, 07:02 PM
My experience is if you don't have a die run the nut down about flush. Otherwise you will mushroom the threads and not all came off. Its easier to use a puller in my opinion.
