Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 06-16-2009, 05:12 PM
deadlysyn08 deadlysyn08 is offline
Gen 2 to gen 1 engine swap
Is it possible to swap a gen 2 sohc neon motor into a 98 highline without heavy modification?
Old 06-17-2009, 08:13 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Gen 2 to gen 1 engine swap
Yes you can, but you should stick to the 00-01 motors if you can. The 2002 and up get a bit more tricky.
2003 Dodge SRT-4
Old 06-19-2009, 08:01 AM
So what modifications, if any would I need to do to put a 00-01 engine in my 98?
Old 06-19-2009, 08:07 AM
You want to use just the block and head. You would use your current manifolds, starter, PCM and so on. You might need to swap some of the 98 sensors onto the 00-01 engine.
2003 Dodge SRT-4
