Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-16-2009, 04:07 PM
coose86's Avatar
coose86 coose86 is offline
Thumbs up 99 gst smoking can you help?
I have a 99 eclipse gst. there is no mods done to the motor or turbo. the only thing that I added was a front mount intercooler and turbo back exhuast. I had the turbo fully rebuilt about a year ago. my problem- when ever I drive the car normally meaning no high boost just city driving the car does not smoke. if I get on it hit high boost and let out, the car smokes alot but only when I let off the gas. If I stay in it the car wont smoke till I come to a stop light. the more I get on it the more It smokes when I let off the gas. Some one told me it might be the valve guide seals but I dont know how to do that or how much it would cost. please help
Old 06-16-2009, 04:50 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: 99 gst smoking can you help?
Hmmm. So regular driving the car doesn't smoke at all, but if you build boost, it does, correct? And the longer you're on it, the more it smokes?
I would pull off the piping off the turbo and check for shaft play. If the shaft can move side to side a lot and/or you can pull it in/out, the turbo is shot. I know you just got it rebuilt, but it may not have been balanced and worn down the seals already. Also, check your O2 housing and intercooler pipes for oil.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 06-17-2009, 08:12 AM
coose86's Avatar
thanks for the advise on checking the turbo I will have to do that. The car acts wierd if I build boost and let out slowly the car wont smoke but if I boost and shift or let out suddenly it will smoke. thats what gets me confused.
Old 06-17-2009, 08:47 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
What color is the smoke? Have you done a boost leak test yet?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 06-17-2009, 10:15 AM
coose86's Avatar
the smoke is dark to light gray. not black smoke. I have not done a boost leak test. is that test in a service manual? do I need any special tools to do this test? thanks for your help
