Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 06-16-2009, 02:40 PM
deadlysyn08 deadlysyn08 is offline
DOHC in Highline?
I was just wondering what I would need to remove or add to my 1998 neon highline to put in a DOHC engine. I already have gotten rid of the air intake over the top of the engine (which is why DOHC had the hood "bump") But I am not sure if I need anything else.
Old 06-17-2009, 08:14 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: DOHC in Highline?
The bulge hood is there to clear the second cam in the engine. It sits a little bit higher.
2003 Dodge SRT-4
Old 06-17-2009, 08:21 AM
So if I got a DOHC and attempted to put it in my car without the hood bulge, would I experience any overly troublesome problems?
Old 06-17-2009, 08:25 AM
The hood may rub on the cam timing cover. I have seen some drop in with no problem others do rub. You can either buy a bulge hood or just cut out the bracing on the flat hood (SOHC).
2003 Dodge SRT-4
Old 06-20-2009, 09:32 AM
So if I decided to go with a DOHC what kind of extra parts and pieces am I looking at modifying or buying to make this thing work?
Old 06-20-2009, 06:13 PM
You need just about everything from the DOHC including the complete engine, wiring harness, PCM and motor mounts.
2003 Dodge SRT-4
