Old 06-16-2009, 02:29 PM
Prof_h Prof_h is offline
Cruise Control problem '97 PA
Hi,
Anyone out there have information on how I can fix my cruise control?
I wanted to access the fuse panel under the instrument panel (driver's side) by removing the hush panel, but I can't find a fuse box under there. The Owner's Manual indicated this is where the fuse panel would be.
What other problems could be causing my cruise control to malfunction?
Thank you.
Old 06-16-2009, 10:32 PM
big white bufflo big white bufflo is offline
Re: Cruise Control problem '97 PA
what is it doing not engaging look for vacuem leaks in the system check for power at the module under the hood if its dropping out while driving look at all your brake ,turn signal lamp
Old 06-17-2009, 11:52 AM
It is not doing anything, I'm guessing no power to the system, therefore I thought fuse, first. All brake and turn signal lamps work fine.
Old 06-17-2009, 01:24 PM
ZiggyPA ZiggyPA is offline
Does the green 'cruise' light work?
Old 06-19-2009, 12:14 PM
The green cruise light comes on during the initial warm up, once I start the engine, then it goes out.
Old 06-20-2009, 12:18 AM
happydog500 happydog500 is offline
Want to be sensitive about hijacking a thread, I have the same problem, but my "Curse" light comes on and stays on. When I push the brake, the light goes out.
Hopefully we can find an answer.
Chris.
1998 Buick Park Avenue (best car GM ever made)
Buick Lesabre 1997, 191,000
152,000 - Motor R.I.P.
Used 111,000 Motor, All New Gaskets
Used 102,000 Transmission - SOLD
New Balance 662
Trek 8000
