Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 06-16-2009, 12:52 PM
BOA279 BOA279 is offline
Unhappy 2000 cougar ***no airflow inside***
Yesterday my wife noticed her Cougar was not putting any air out to defog the windshied. I took a look and noticed it would not put air out anywhere. Took out the glovebox to look at the fan...the fan runs at its various speeds but none of the solenoid valves opens. Basically the fan is trying to blow into an enclosed chamber causing the fan to make strange noises. With the glove box out I was able to manually move the solenoid for the windshield and air came flying out like normal...nice and strong.
What could cause all positions to not work at once? I noticed that the solenoids that control the positions are all vacuum controlled. Is it possible the vacuum is not working causing all to fail? where in the engine bay does the vacuum come from and where behind the dash is the solenoid that allows the vacuum to be applied to each of the vacuum controlled "flapper" for the different positions?? Is there a fuse that only has to do with position control???
Any help appreciated!
THANKS
Old 01-24-2010, 07:27 AM
justthe6 justthe6 is offline
Re: 2000 cougar ***no airflow inside***
i believe there is heater resistor that runs the heater controls, it is a knob design so it wont have a cable to adjust the linkage to control the heater vents and where and when they blow heat out. the resistor should be located behind you dashboard where the heater controls are.if you take it out check where the plug goes into the back of it and see if the wires looks burned or worn through. if you tested the blower motor and the motor is working then that would be my best guess. good luck.
