Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Non-Performance
Non-Performance This is the place to discuss interior, exterior, and other non-performance related modifications.
Old 06-15-2009, 03:26 PM
lilsweets3138's Avatar
lilsweets3138 lilsweets3138 is offline
Send a message via Yahoo to lilsweets3138
Leak in wiper fluid container
I just found out I have a leak in my wiper fluid container. Is there somekind of sealer I can use by sticking inside the container or does the whole thing have to be replaced?
I also have a photo,it's not clear where the exact location is but you can tell it's a leak.The container is EMPTY,I am assuming the crack is near If not on the bottom.
Thanks again
www.cardomain.com/ride/2821880
Old 06-15-2009, 07:42 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: Leak in wiper fluid container
remove the whole thing from the car, and fix the crack with some epoxy... finished.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 06-30-2009, 04:37 PM
I just wanted to update you guys just incase anyone ever has a leak in there wiper fluid container.Always check first before assuming what the problem is.While my car was on the lift I went to check it out and there was actually no crack or anything like that.
There was a tube that has a boot on the end,well it seems it came disconnected so I just popped it back on and tada!
Old 07-01-2009, 10:00 PM
J-Ri's Avatar
J-Ri J-Ri is offline
That's somewhat common. Whenever I reinstall one, I put a #2 clamp on both sides of the elbow to keep it from coming off again. They get soft with age and pull off much easier than they should. Don't tighten the clamp much, you don't want to crack the pump or the line, just enough that the elbow doesn't pull off easily.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 07-04-2009, 06:20 AM
Gary888 Gary888 is offline
If you do have a crack some day. I have had good luck fixing a crack after a wreck with a soldiering iron. Melting the crack together. Rubbing towards the crack with the hot iron from each side.
