Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 06-15-2009, 10:10 AM
will1976 will1976 is offline
Broken Caliper Bolt
Hello, My caliper bolt broke while replacing the brakepads. I drilled my last one out on a previous car. This bolt started to drill out shavings but then stopped halfway through. I am using a new craftsman hardsteel drillbit with pb blaster with no results. The steel seems to have hardened. Is there a better way of removing a broken caliper hexbolt?
Old 06-15-2009, 12:42 PM
maxwedge maxwedge is offline
A990 racer
Re: Broken Caliper Bolt
If you can get the caliper off, just get a rebuilt one, no? BTW, always post the year and model.
Old 06-16-2009, 09:32 AM
1991 oldsmobile cutlass cruiser 3.3L v6. The caliper is attached with one hexbolt that is broke in half.
Old 06-16-2009, 06:56 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
You can remove the caliper mounting bracket to get a better angle on drilling out the caliper bolt. might also try something beside PB, it could lube the bit to much and its not bitting into the bolt.
1999 Grand Am SS 3.4 OHV
Old 06-18-2009, 09:23 AM
I removed the Hexbolt with a hacksaw. Took awhile but worked. Thanks for the help.
