Old 04-01-2003, 03:27 PM
JeffK JeffK is offline
Rough Running S-10
Hi. I have a 1994 S-10 Blazer, 4.3L with about 85k on it. A couple days ago it began to run real rough. While idling, the engine revs up and then drops off... it sounds louder too. When I am driving a highway speeds I do not notice it as much, but when I let of the gas and begin slowing it gets more and more noticeable. Any thoughts....
Thanks
Jeff
ps... I just checked the EGR Valve. I pulled the valve, plugged the hose and it ran the same way... rough!!
Old 05-01-2003, 03:12 PM
Scorpio7's Avatar
Scorpio7 Scorpio7 is offline
Send a message via Yahoo to Scorpio7
Red face One Answer To Your ??????
Have you replaced your Throttle Position Sensor? It sounds like a problem that this piece causes when the transmission (automatic) and the idle speed control are also not working properly.
Have you any engine light codes flashing on your dashboards??
Later Angelo/Scorpio7
Old 09-17-2003, 11:00 PM
nevinsb nevinsb is offline
I bet you got a chunk of carbon in your EGR valve. The same thing happened to me. The engine surges and just about dies. The new gasket has a screen in it that will prevent foreign objects from entering the EGR valve. This is a very common problem with that motor. Using a top engine cleaner such as seafoam to remove carbon usually can cause large chunks of carbon flyin' round the cylenders to get lodged in the EGR valve, so If you are planing on doing so, do it BEFORE you take the EGR valve out so you don't have to do it twice.
Old 10-08-2005, 03:12 PM
ddjaa ddjaa is offline
Re: Rough Running S-10
Thanks
Jeff
Hey, got the same problem with 92 blazer, runs ok once you get moving then if you go to stop it surges and stuff. You go to start it after awhile you have to give it gas, whats up????????
93 Jeep Cherokee Running Rough bbbyblumer Cherokee 3 06-08-2010 07:49 AM
93 lesabre runs rough and stalling pigeonkiller LeSabre 4 01-10-2010 06:30 PM
89 Mustang LX, rough idle and runs terrible. Ericdano Mustang Problem Diagnosis 2 11-07-2009 02:14 AM
Rough running S-10 4.3 4x4 SkremenGSXR S-10 3 01-30-2005 01:44 PM
