Go Back   Automotive Forums Car Chat > Chevrolet > Chevelle
Old 06-14-2009, 08:51 PM
LV1 LV1 is offline
68 Malibu convertable
Hello,
I am a new member here, Look like a very interesting forum. Anyway, My 68 has a (72) 350,I started having charging problem's, Took the battery out and had it checked! They said battery was good, Bought a ext regulator and put that on, No luck, Still only charges a little over 10 volt's!
Getting discusted, Must be the alternator, Took it off and matched it up at the part's house, Put it on with same outcome a little over 10 volts! Then it dawned on me that my car has a external and internal regulator
It look's like the previos owner wired it for a internal reg. Now after all the new parts, to get it to charge I have the old ext. plus the new internal regulator's plugged in!!! Any ideas?
Thank's, LV1
Old 06-16-2009, 06:59 PM
mdcamaro mdcamaro is offline
Talking Re: 68 Malibu convertable
Get this conversion kit from M & H.
http://www.wiringharness.com/
External Regulated Alternator to Internal Regulated Alternator
Conversion Kit for 1963 to 1972 GM Cars and Trucks
If the harnesses in your car are in good shape, but you would like to get rid of your external regulated alternator and install an internal regulated alternator this kits for you. Easy to install: 1) Disconnect your external voltage regulator leads and plug in our "Special Regulator Adapter" to the regulator lead wires. 2) Disconnect your alternator lead wires. 3) Install new GM internal regulated alternator. 4) Plug in our "Special Alternator Adapter" to the alternator lead wires. That's really how simple it is. Part # 27555. Price $19.00. Includes both adapters and instruction sheet. We also offer free technical support if you can't figure it out.
Old 12-14-2010, 06:29 PM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
DO NOT USE TWO REGULATORS!!!!! Bad things will happen. Check all connections negative post to inner fender....engine block to fire wall.....On internally regulated alternators you run a wire from the field (bolt) terminal on the back of the alternator to the battery, Then run a jumper wire from that bolt straight to the closest electrical terminal on the alternator then the last remaining terminal you run a wire to a ignition switch with power on in the run position.
