93 blazer is dead i need help!
ok im tired of beating my head against a wall on this one..i bought a 93 s10 blazer that ran fine untill lately. it did have the SES light on. i had it checked and it was the knock sensor. but as i said it ran fine. i found out that the 4.3 vortec was from a 1991 blazer. i was driving and it acted like it ran out of fuel. and would not start for an hour. then it started right up but was running rough. so i changed the fuel pump and filter. after it started and idled fine but would miss out until about 25 mph then it ran fine. then about 2 hours later it died and wont start. ive checked the coil and it has spark. i have not checked the fuel pressure on a gauge but there is fuel at the injecters. i want to exaust all options before taking it to a shop for a knock sensor. any ideas would be great.
Re: 93 blazer is dead i need help!
When it quits check for lose of fuel pressure or spark to plugs.
Fuel pressure specs is 9-13 lbs of pressure.
MT his 93 may be like my old 93 was, CPI so it would need 55-60 lbs if that is the case. If his is TB unit then you would be right. Most 93s were CPI. A problem too. Invest in a fuel pressure guage, a service manual, and if fuel is OK then have the igniton module(in distributor) checked. Might be failing when heated up.
I used to be indecisive, now I am not so sure. |
No engine code given and he said it was from a 91. I was going by what he said on seeing fuel at injectors for TB injecton..
