Old 06-14-2009, 02:14 PM
mikemrq mikemrq is offline
Wheel Bearings
Have a 2001 Cavalier 2.2, need to replace the front Wheel Bearings. Are there any instructions here on how to replace them before I start the job?
Old 06-14-2009, 03:18 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Wheel Bearings
It's pretty easy. Loosen the lug nuts and remove the axle nut while it's on the ground. Raise and support the vehicle with jack stands. Remove the wheels and remove the 3 bolts from the hub assembly. If the hub assembly is rusted to the axleshaft, thread the nut back on so it's flush with the end of the shaft and hit it with a hammer. Once it breaks loose the hub assembly should just pull off. You may need to hit it from the back side to break it free of the rust in the steering knuckle.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
