Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-14-2009, 01:20 PM
longydongy longydongy is offline
CEL p0442 Can an exhaust leak cause this code?
Hi,
Looking for some help with this CEL P0442 code. Vehicle is '99 Rodeo sport 4x4 auto with the 3.2L. I have cleaned the EGR tube about 5 months ago and just changed the gas cap 2 days ago and the same codes came back today. Actually it was 2 codes both being the p0442- the other was p0442 PD. Not sure what the difference is? I have found an exhaust leak between the tail pipe and muffler and was wondering if this could be causing this code? Or I was thinking of changing the gasket at the EGR valve as I resued it last time I cleaned the EGR tube. I checked the vent hoses from the tank to the EVAP canister and everything appeared OK. Any help would be greatly appreciated!!
Old 06-14-2009, 04:41 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: CEL p0442 Can an exhaust leak cause this code?
My flex tube has blown out for a couple of years and i had no codes so I don't think a exhaust leak where yours is at would cause a code.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 06-14-2009, 11:17 PM
Cat Fuzz Cat Fuzz is offline
An exhaust leak has nothing to do with this code. There has been a leak detected in the evap system somewhere. The leak can be very tiny and still be detected. The p0442PD simply means "pending". In some cases, when the PCM sees a fault it doesn't set a code right away but instead stores a pending code. If it sees the fault again, then it will set the code and turn on the check engine light.
Here is a link to more information about this code: http://www.obd-codes.com/p0442
If you can't visually find the leak, you may have to have a pro find the leak with what is called a smoke machine. This is a tool specially designed to connect to the evap system and help find the leak.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 06-15-2009, 09:03 AM
Thanks for the advice. I was afraid this wouldn't be that easy of a fix. I guess I'll crawl back under it and start checking hoses tonight.... Does anyone know how to troubleshoot the EVAP valves?
Old 06-19-2009, 08:13 AM
Does anyone know how to troubleshoot the EVAP solenoid valves?
