Go Back   Automotive Forums Car Chat > Mazda > 626/Capella/Capella Wagon
Old 06-14-2009, 10:00 AM
loucaf loucaf is offline
2001 mazda alarm goes off
I have a 2001 mazda 626 and the alarm goes off for no reason...any ideas?
Old 06-15-2009, 12:37 PM
1=2 1=2 is offline
Re: 2001 mazda alarm goes off
If it's aftermarket, it's probably hypersensitive in terms of the setting it's on. Had a Cherokee that would go off if I leaned on it. There should be a little box somewhere on the car (most likely under the dash around the fuse box) where you can turn a dial down or up. Turning it down should prevent it from going off.
If it's not aftermarket, refer to the owners manual for adjustment, if there is a place. If not, look online to see if you can set the sensitivity.
Old 06-16-2009, 07:13 AM
thanks, I'll take a look and see if there is a setting adjustment. The alarm is factory standard.
