Old 06-14-2009, 07:47 AM
SuperMele's Avatar
SuperMele SuperMele is offline
Tamiya Sauber-Mercedes C9
Started this build for a groupbuild on another forum...
Introduction:
Box:
Parts:
Decals and instructions:
Pe from the box and matched paint:
Some progress:
Mutch better:
First this :
In to this (needs some cleaning up):
Rims done:
Primed and taped:
Black:
Tape off:
Tape back on:
Mix from yellow and smoke:
Tape off:
Some weathering:
And thats it for now...
Greetings
Old 06-14-2009, 10:16 AM
TRBJ TRBJ is offline
Send a message via MSN to TRBJ Send a message via Skype™ to TRBJ
Re: Tamiya Sauber-Mercedes C9
ths for the smoke+yellow tip!!!
sylvia
Old 06-17-2009, 03:30 PM
Outamyhead Outamyhead is offline
Nice work so far, I managed to pick up the very same model about a month ago, it might be the next build after my Mazda 787 get's finished off. Never built a model with PE yet, anything I should be aware of or any tools like an angle bender needed at all?
Old 06-17-2009, 06:54 PM
gasdriverca's Avatar
gasdriverca gasdriverca is offline
Send a message via Yahoo to gasdriverca
Is the mix of smoke and yellow suppose to be kevlar? if so nice one !
Old 06-18-2009, 01:21 PM
SuperMele's Avatar
Hey outamyhead, first time i use pe also You need to bend some parts, like 1 and 2 from the pe set, they have to be in the same shape as the front wheel arches... Havent done that yet Only bended one thing and thats the front towhook, needs to be an 90° angle but you can easily do that with tweezers...
I think so, i just mixed the paint with tamiya's instructions.
Greetz
Old 06-18-2009, 04:08 PM
rollover's Avatar
rollover rollover is offline
It looks like your off to a good start. I like your detailing so far on the engine and bulkhead.
Jeff Grebe, Plasticrastinator
Not finishing kits, My specialty
Old 06-18-2009, 07:17 PM
lemansnut lemansnut is offline
Nice start so far. Tamiya has had a couple different mixes to try to simulate the kevlar, I think they use the same mix on the Mazda 787B. You should check some reference pictures for the rear crossmember though, it should not be opened up as you have done but webbed as the part is supplied. Keep going, it's a really nice kit. Looking forward to more progress.
Mike
Old 06-21-2009, 12:40 PM
SuperMele's Avatar
Update time...
Pe in place:
Primer:
Sauber blue:
Thin coats of clear added to help give the decals a smoother surface to attach on.
Many houres later with a painfull back of constantly bending forward :
Engine primed:
And thats it again...
Greetings
Old 06-21-2009, 01:09 PM
klutz_100's Avatar
Looks super!
Almost makes me want to break out my Revel kit LOL
Old 06-21-2009, 01:45 PM
Sebastian.'s Avatar
Sebastian. Sebastian. is offline
Send a message via ICQ to Sebastian.
You have forgotten, that the forward part should be a single whole! You have not cleaned a crack where details are joined!!
Old 06-21-2009, 02:07 PM
SuperMele's Avatar
On the boxart you can clearly see the pannelline of the 2 pieces...
I dont really build my models 100% like in real life and spend time first on searching the web to see if its really intended to be build as tamiya says.
Old 06-21-2009, 04:23 PM
guiwee's Avatar
guiwee guiwee is offline
I dont understand why the p/e covers those vents..I mean why have vents at all if
their gonna be covered up?This kit reminds me of my 956
Old 06-21-2009, 04:30 PM
Modelerone Modelerone is offline
The vents might be open or covered depending on track and race variables. Open for a track with a lot of braking or very high temps to help cool the brakes or closed for better aerodynamics if additional cooling is not required.
Old 06-21-2009, 05:09 PM
jano11 jano11 is offline
Originally Posted by klutz_100 View Post
Looks super!
A good kit that one, because it's actually a Hasegawa!
Old 06-21-2009, 06:12 PM
rollover's Avatar
Good job on the decals, they have always scared me away from this kit. Too many right angles and parrallel lines.
What color did you use on the wheels?
