Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 06-13-2009, 08:47 PM
cvgt3 cvgt3 is offline
Tiny found , motor pending
tiny contacted today ... he has been busy ... but states my motor is about to be dynoed... he will talk to me monday .... sounds good... keep you posted chip valente
Old 06-13-2009, 09:50 PM
jmimac351's Avatar
jmimac351 jmimac351 is offline
Re: Tiny found , motor pending
Chip, are you planning to dry sump this motor?
Jim McGovern
~ Building 289 Lemans Replica
~ '92 Mustang Coupe: 347ci / Carb
Pictures
Old 06-13-2009, 10:07 PM
jim one motor in N C at T and L engines... the first time they did not think it needed a dry sump... engine failed while running the feb 7 th race at sebring.. I asked them to dry sump the new one....the old one that tiny is building could be ill see what happens chip
Old 06-15-2009, 04:15 PM
NZGTRA17 NZGTRA17 is offline
Chip, what engine configuration are you running (i.e. std bore / stroke 351) or other?
When you say the enginre failed, did it lose oil pressure and spin a bearing or other?
Assume you are using the std Panoz supplied wet sump?
Thanks, Kel.
Kel M
Panoz GTRA #17
New Zealand
