I Have a few idea's what it might be but not certian. I have changed the plug wires (accel 8.8's) the factory wires definately clear the wallet in a hurry, run injector cleaner a few times also cleaned as many contact's as I could find ( including taking the coil pacs off and making sure for good contact with the prongs ). I did do a few mods to the car, I was suckered into buying that silly juice box wich I believe now is just a diode in a box
. Ported and pollished the throttlebody (very carefully at that). Also made the exhaut flow a lot better but I can't see that being the colpurate. Now come to think of it, I do remember having to replace both rubber hoses going to the heater core. It was spraying a lot of coolant on the coolant temp sensor and connector. That may be a problem right there but I have no idea darn it
. The car works a lot better at higher rpm but still misses the odd time. I am really leaning toward's an ignition issue.
I need some reasurance to what it would most probably be.
Thank you very much
