Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 06-13-2009, 01:41 PM
Persistent One Persistent One is offline
hood shakin
can anybody tell me how i can adjust my hood to where it wont shake when i drive down the road? thank you
Old 06-13-2009, 02:20 PM
patbeechermail's Avatar
patbeechermail patbeechermail is offline
Re: hood shakin
Not sure what your problem is but you cn try lookin at your latching mechanism under you hood. Check for loose bolt and such. If all is well then check for any parts that may be bent out of whack and straighten up. In some instances i have been able to tighten hoods by bending the latch for a snugger close.
Old 06-14-2009, 05:14 PM
XGamesJ6's Avatar
XGamesJ6 XGamesJ6 is offline
Re: hood shakin
If u look on the core support, at either end you'll find these little rubber stoppers, in most cases you can just grab it and turn it like a screw You can move it a bit so the rubber feet are higher, so the hood will latch tightly, but wont bounce around, hope it helps!
2009 Pontiac G6 2.4L L4
2007 Buick Lucerne CXL 3.8L V6
2007 Chevrolet TrailBlazer LT 4.2L L6
1993 Oldsmobile Cutlass Supreme SL 3.1L V6
