Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 06-13-2009, 11:41 AM
MoS_19Delta MoS_19Delta is offline
Blew a drain plug!!!
The 88 blew a radiator drain plug in the parking lot the other day. Anyone know what the prob could be? or how to fix it fast?
Old 06-15-2009, 09:30 AM
Davescort97 Davescort97 is offline
Escort guy
Re: Blew a drain plug!!!
Most likely it was cross threaded the last time it was put in. A new plug should hold and not give you any more problems. A new radiator cap should keep the pressure from building up and doing it again.
Old 06-15-2009, 03:49 PM
ok cool, thanks. I've also got a coolant leak, it looks like it's coming from the head cover. Is that possible? I don't know much about cooling systems. I don't really have cash floating around so i'm trying to fix it myself. Any ideas or possible fixes?
Old 06-15-2009, 08:19 PM
rhandwor rhandwor is offline
If anti freeze is coming out by the valve cover you could have a leaking intake gasket of cracked intake. Clean it and use a flashlight and determine what is leaking.
