Old 06-12-2009, 01:28 PM
herkyhawki herkyhawki is offline
Code P1870 again, new valve body already
1998,5.7L, 4L60E, 4x4, 3.42 rear end. 115,000miles on truck. Previous owner installed reman trans at 70,000 miles due to "sun gears exploded,.. manufacture defect in original tranny".
Getting hard shifts after 30-mile highway drive. After the second 30-mile trip I get check engine light and code P1870 (trans. slipping). Trans oil is clean, not burnt, and no major debris in pan.
Trans shop installed valve body kit $280. Still same problem.
Then Trans shop replaced valve body with re-manufactured VB (no $ charge). Says trans fluid is clean, very small amount debris (maybe brass) found in pan. Same problem P1870 code on after two highway test drives.
If I reset the code and drive around town, or short hwy miles, the code does not set, only after 2 consecutive trips of 30+ miles. I understand from reading many internet sites, that this is the proper funtion of the P1870 code setting logic.
Trans shop #1 suggests to change Torque converter, but says he will take a long, 30 minute drive with a scanner before starting, in case something else shows up.
Trans shop #2 after my description says for sure it needs a rebuild because 3rd/4th clutches are slipping.
Any advice??
Can the scanner really determine which component, such as Torque converter is causing the slip? I just don't want to buy a TC and then come back for the whole tranny rebuild.
How hard is it to drop the tranny and replace Torque Converter DIY? Shop wants about $300 labor + 160 parts. I see rebuilt TC's for sale for about $125-150
Old 06-13-2009, 08:48 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Code P1870 again, new valve body already
Code 1870 leads to internal lose of transmission pressure.
No band aids there.
Rebuild or replace it and be done with it.
MT
Old 06-13-2009, 07:38 PM
Thanks , but I'm just trying to make a fact-based diagnosis of the problem.
From what I've read, P1870 is set when the PCM senses slippage between crankshaft and driveshaft. Your advice would make sense only if this if is incorrect, so please correct me if needed.
Does P1870 sense crankshaft-to-driveshaft or does it sense transmission-input-shaft to driveshaft??
When slippage is detected, the PCM raises the pressure to try to limit the slippage.
My question is if a high-end scanner is able to provide enough information to determine if the slippage is in the torque converter or if the slippage is in the transmission itself.
A typical trans rebuild includes a new Torque converter, so the question is usually not answered (was the trans slipping? or was the torque converter clutch slipping?)
The total rebuild solution does not find the source of the problem, and the conventional wisdom of "replace it all" is only to the benefit of the mechanic that was unable to make the diagnosis. Why spend money on parts that have not failed???
Old 06-14-2009, 09:29 AM
MT-2500's Avatar
AF - Advisor
To answer your first question.
Yes a good scanner will pinpoint where the slippage is.
But the root cause of slippage is internal transmission pressure leakage.
There is a lot of band aids like valve body and converter replacement if the converter is where it is slipping.
But it always goes back to internal pressure leakage as the root cause.
And the only long term fix is to fix the internal leakage.
Which will take a transmission rebuild or replacement.
Good Luck
MT
Old 06-14-2009, 10:02 AM
MT-2500's Avatar
AF - Advisor
Diagnostic Information on DTC P0894 and P1870 #02-07-30-001A - (02/11/2004)
2000-2004 Passenger Cars and Light Duty Trucks
2003-2004 HUMMER H2
with 4L60-E or 4L65-E Automatic Transmission
This bulletin is being revised to include additional model years and additional diagnostic information. Please discard Corporate Bulletin Number 02-07-30-001 (Section 07 -- Transmission/Transaxle).
Diagnostic trouble codes (DTC) P0894 and P1870, Transmission Component Slipping, may have different root causes. The following diagnostic tips are provided to assist in accurately repairing the condition.
Corporate Bulletin Number 01-07-30-023A, dated November 2001, is intended for 1996-1999 vehicles with more than 32,000 km (20,000 mi). This bulletin addresses wear in the valve body TCC isolator/regulator bore, which can cause DTC P1870. This wear condition is not the cause of DTC P0894 or P1870 on any 2000 model year vehicle built after January 15, 2000, or any 2001 or newer vehicles as the valve body used on these vehicles has been revised to prevent the wear condition.
Corporate Bulletin Number 99-07-30-005, dated March 1999, should be used to help with diagnosis of these DTC's. This bulletin will help to determine if the DTC is caused by the TCC system or by a slipping internal transmission component such as a clutch or band.
Slip speeds greater than about 250 rpm at steady state driving are caused by a slipping clutch or band.
Slip speeds below 250 rpm at steady state driving are usually caused by the TCC not applying but may also be caused by a slipping clutch or band.
A plugged or restricted TCC apply fluid orifice (238, located in the pump) may cause DTC P0894 or P1870, especially in low mileage vehicles with less than 8,000 km (5,000 mi).
A converter clutch valve (224, located in the pump), which does not have full travel of 13 mm (0.5 in) or is stuck in the off position may cause DTC P0894 or P1870. Inspect the valve for chips, debris, nicks or burrs. Also, inspect the springs (225 and 226) to make sure they are not limiting valve travel. A spring that is not fully wound may catch in the bore, limit valve travel and cause DTC P0894 or P1870.
A cracked or leaking TCC solenoid (part of harness 66) may cause DTC P0894 or P1870. Use solenoid test kit J 44246 to test the operation of this solenoid.
A cracked or leaking TCC PWM solenoid (396) may also cause DTC P0894 or P1870.
When attempting to diagnose a DTC P0894 or P1870, it is important to also refer to the appropriate Service Manual for further possible causes of this condition.
MT
Old 06-14-2009, 05:27 PM
777stickman 777stickman is offline
The thing with this P1870 code is that it inhibits TCC lock up when this code is active. As MT-2500 stated, a high end scan tool is required. The scan tool can command the TCC to lock up and then it can be determined, in the hands of a knowledgeable person, if the problem is the in the TCC components, which there are several, or other internal issues.
In the trouble shooting tree for this code there are 13 different steps, 10 of which require inspections of internal components.
One question for you. Does your tranny shift into reverse??
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 06-14-2009, 10:02 PM
Yes Reverse works fine. All shifts seem to work fine until P1870 comes on then hard shifting starts.
Tonite I took a short drive 2 miles pulling small boat and the backed into garage, uphill driveway into garage.. About 30 minutes later I crawled under truck..engine oil pan and trans oil pan were cool to touch. Removed small access cover to Torque converter and stuck fingers in to find Torque converter was very hot. Is this a clue??
I have appt. with Trans shop #1 Tuesday. He said he will take for a long drive with scanner connected, and he invited me to ride along. Maybe I'll learn something if I can make time to go along.
Old 06-18-2009, 09:30 PM
Trans. Shop #1 thinks they got it fixed. It was a bad sensor that turns on TCC. $50.00 sensor was much better than $1400.00 rebuild. Need some highway time before I'm really comfortable that it's fixed.
Old 01-28-2010, 08:28 AM
Shade Tree Mec Shade Tree Mec is offline
Hi herkyhawki
Am having the same problem it drove me crazy, could you please give us more details about the sensor you changed? and if that solved the issue?
thanks
Old 01-28-2010, 09:35 AM
Thanks (not) for bringing back a bad memory.
I'll skip the longest part of the story that included me buying a torque converter that I probably did not need.
The tans. shop finally figured out it was not the sensor, but a valve in the tranny. I don't rmember what it was called, but was not a solenoid valve. It was a $130 spool-type valve that has something to do with locking up the torque converter. Transmission has worked perfectly ever since, and code never came back.
Old 01-28-2010, 09:44 AM
Am sorry bringing back this bad experience, am living it right now, i had changed the whole tranny with a used one but it did not fix the problem, I know the valve you are talking about it is the correction kit for the worn TCC valve, I hope you never face such a problem in the future.
I'll buy this kit and see if it would solve the problem
Thanks Man
Old 01-28-2010, 11:21 AM
transman618 transman618 is offline
Thanks Man
P-1870 means "Transmission component slipping". A very common problem with these transmissions which sets a P-1870 is 2 valves in the valve body, the TCC regulator and isolator valves. The reason for the problem is these valves wear out their respective bores, the converter clutch apply oil passes by the worn valves lowering the apply pressure of the converter clutch. The clutch then starts slipping and chattering, sets a P-1870 and maxes out the line pressure causing harsh shifts. You replaced your transmission with a used transmission which most likely had the same common problem. The way I usually fix these is with a kit from Sonnax. The valve body is removed, both tcc regulator and isolator valves are removed, their bores reamed, sleeves installed with new valves. This is what needs to be done and will cure 95% of P-1870 issues.
transman
GM MASTER TECHNICIAN
SR. TRANSMISSION BUILDER
Old 01-28-2010, 02:33 PM
transman
Transman thanks for your paticipation here, but what I would like to clearify is: I have a 4L80e tranny, and sonnax sales only the TCC regulator valve kit (which is sold in either valve/spring kit or valve/spring/sleeve kit),
And since you are TransMan, could you please guide me on how to ream the valve body, since the installation of the Sonnax kit needs a special tool, that is not available in my country and it gonna cost about 200$, is there anyway to ream the valve body without using Sonnax tool?
Am much leaning toward the sleeve kit.
Here are the kit that am referring to:
1- Regulator Kit: http://www.sonnax.com/part_summary.php?id=3624&pl=3
2- Regulator Kit with sleeve: http://www.sonnax.com/part_summary.php?id=4975&pl=3
3- Special Tool (which I cant afford and not available in my country): http://www.sonnax.com/part_summary.php?id=4976&pl=3
Old 01-28-2010, 03:22 PM
j cAT j cAT is offline
check this out http://www.transmissionpartsusa.com/...show=30&page=1
Old 01-28-2010, 03:58 PM
Originally Posted by j cAT View Post
I have just emailed them looking for the sleeve kit, and that was just 5 min before your post,
