Old 06-12-2009, 10:51 AM
weber45ca weber45ca is offline
01 Grand Prix GT front Axle Nut torque
Hello,
I've been thru the posts and I've found a few different answers for the torque used on the axle nut. I'm replacing the HUB Bearing on a 2001 Grand Prix GT.
Can anyone give me any info on this?
Thanks
Weber
Old 06-12-2009, 12:16 PM
toddman67 toddman67 is offline
Re: 01 Grand Prix GT front Axle Nut torque
36mm nut, 118ft lbs.
Old 06-12-2009, 12:40 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
01 was a changeover year. If you bought an aftermarket hub and it has a torque spec in the box, follow that as they sometimes require a different torque than factory spec. If there is no torque spec in the box, you need to look at the ABS wiring connector and see if it has a stainless steel (1st design) or plastic clip (2nd design) that holds it on the bracket, as each design uses a different factory torque spec.
1st design w/stainless clip- 118 ft/lbs
2nd design w/plastic clip- 151 ft/lbs
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 06-12-2009, 12:52 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Make sure you check inside the box. Sometimes bearing manufacturers will request a different torque spec for there bearing.
Old 06-12-2009, 01:28 PM
I'm pretty sure mine is the plastic clip one.
Thanks for the help
Weber
Old 06-12-2009, 07:43 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
If I remember right the BCA hub I used requested a torque spec right around 130 ft lbs, but dont quote me on that.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
