Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 06-11-2009, 08:38 AM
drew300 drew300 is offline
Dead A/c
I don't know a lot about A/C systems, but while trying to trouble shoot mine, i found that the low pressure side "filling" valve had a leak.
I found the A/C didn't work this spring and that the pressure was low. I put a can of refrigerant in, and it worked for about 3 days, then it was low again and not working. While looking at the system for oil spots, (leaks), I heard a slight hiss from the valve. I tapped the valve pin to reseat it, but it still hissed. I put an O-ring on the stud of the cap, added some more refrigerant, and it's still working after 2 weeks.
Is this a good fix, or what would be recommended? Is this common?
Thanks
Old 06-13-2009, 08:45 PM
RC1488 RC1488 is offline
Re: Dead A/c
If it works then its good. A/C systems are expensive to get fixed, so anything you can do to get it to work is the best haha
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
