Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-11-2009, 02:30 AM
Cavalier9696's Avatar
Cavalier9696 Cavalier9696 is offline
Send a message via Yahoo to Cavalier9696
95 RS Tail light
My tail lights will not go off. I can turn off the car and all the lights and the tail lights seem to stay on. The only way I get them off is by unpluging them. To weird.
Old 06-11-2009, 03:35 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: 95 RS Tail light
So I'm slightly confused, all of your lights stay on after shutting it off or just your tail lights? You said when you shut the car off... You mean when you shut the lights off, right? Have you changed anything in the wiring recently since the problem has began?
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 06-11-2009, 06:36 AM
My bad its my break lights that wont go off. All the other lights go off but those. Nothing has been changed with the wiring. I drove it to work last night and when I got out I noticed they were still on. Someone told me to look under the dash at the top of my break pedal at a plug and reset it or something.
I looked and found a plug but of no idea how to reset it or if that is even the problem.
Old 06-11-2009, 10:20 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
That switch is what cuts your brake lights on. It is possible for it to be stuck 'on'.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 06-12-2009, 02:19 AM
Where exactly is the switch? All I have found is a plug going into round shaped thing above the break pedal. How would I flip it back off?
Old 06-17-2009, 09:27 AM
coose86's Avatar
coose86 coose86 is offline
the switch is going to be located on the brake pedal itself. Disconnect the connector and see if the brake lights turn off. If they do then you will need a brake lamp switch. If they dont turn off then you have a wiring issue.
