Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 06-09-2009, 08:30 PM
motorzonesuzuki motorzonesuzuki is offline
00 Deville no start
Hello,
I have a 2000 Cadillac Deville. It doesn't start, or even turn over. The gear shift lever indicates that it is in Drive 4 all the time. I have a Tech II scanner and it says that the transmission is in 2nd gear and the inticator is in Drive 4. The indicator does not change when shifting gears. I jumpered the starter relay, and it turns over, but still won't start. I believe it is the park safety switch. Any other ideas, Thanks Motorzonesuzuki
Old 06-10-2009, 08:22 AM
maxwedge maxwedge is offline
A990 racer
Re: 00 Deville no start
Sounds like the prndl sensor,it is mounted on the trans linkage where it enters the trans case. Check for any TSB"s regarding this condition.
Old 06-12-2009, 12:16 PM
I found the problem. I removed the bottom pan and found that the rod that runs from the internal mode switch to the parking pawl has a plastic clip broken. Replaced clip, and now works great.
