Old 06-09-2009, 08:11 PM
brent dawson brent dawson is offline
stalls when put in gear
i have a 94 z24 cavalier that runs and idles fine but when put into gear and brake is released it gives a jerk and shuts off. does anyone know what this could be? the mechanic that worked on it b4 said there was a "brake" on the trans that he unhooked and i was thinking maybe this brake somehow got pinched and is locking up the trans... please reply with any insight thanks
Old 06-10-2009, 09:03 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: stalls when put in gear
Check codes. If there are any, post them. Whether or not there are any, try wiggling/pulling on wires that flex when the engine is put into gear.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 08-05-2009, 02:45 PM
ooshal77 ooshal77 is offline
i have a 2004 cavalier ls, and it jus wont start, it does kinda start but theres no power, i mean i have one of those loud mufflers on 2 but when it starts it just sounds like a stock vehicle, and we changed da fuel pump, fuel filter, got another fuel pressure regulator, got n new coil and a new module 2 and it still wont start, i need help!!!! PLEASE, WHAT COULD IT BE?
Tags
cavalier , chevy , stall , transmission
