Fuel pump Pressure- 97 lesabre
I have been checking everything for my stalling out problem. After reading these forums I decided to check my Fuel pressure............what do you guys think of these pressures............
At key on ,engine off- 49 PSI At Idle- 40 PSI Vacuum line removed from Fuel Pressure Regulator- 50 PSI Also when I removed the vacuum line from the FPR I noticed a little gas spitting out of the regulator.Is this normal ??? thanks. |
Re: Fuel pump Pressure- 97 lesabre
Looks like you found your problem. There should be no gasoline in the vacuum line, only vacuum. You'll need to replace your fuel regulator. |
would this cause a stalling out while driving?...........usually when decelerating.
Yes, you are sucking raw fuel into the intake through the vacuum line. There was a recall on the 98-2000 regulators, but should have included 97! Under certain conditions, a leaking FPR can cause a backfire & explosion. I have actually seen some manifolds totally disintegrate with the explosion. Change that FPR ASAP!
Knowledge can be communicated, but not wisdom! ![]() ![]() |
Thanks.I will replace asap.........What is the purpose of the FPR ? to keep a constant
pressure at all times or does it fluctuate with accell and decel ?? Do you know what the normal press. should be with the vacuum line off ? |
The pressure fluctuates with engine vacuum, the lower the vacuum the higher the pressure, the higher the vacuum, the lower the pressure. BTW, check your hotmail, I sent you the GM recall notice in pdf. Click Here for a few pics of the manifold explosion! Good luck!
thanks for you help...
