Go Back   Automotive Forums Car Chat > Oldsmobile > Oldsmobile Classics
Old 06-09-2009, 06:36 PM
70cutlass 70cutlass is offline
carter carb
I recently put a carter 600 carb on my 70 cutlass,2 problems,1 there are no instructions on adjusting the air fuel ratio,2 where does the fuel filter go or do I need an in-line filter.
Old 06-09-2009, 07:06 PM
maxwedge maxwedge is offline
A990 racer
Re: carter carb
Welcome to AF, once it is running and the engine is warmed up, get a vacuum gage on it and turn each mixture screw in til the vacuum drops, then back out about 1/4 to 1/2 turn till you have the highest readings. This is done at an idle speed of about 650-700. In the future a little more info, stock engine, and what size? Yes you need a fuel filter, usually between the fuel pump and carb.
Old 06-10-2009, 07:22 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: carter carb
My dad had a 1970 Cutlass. Great car, strong engine, even though it was 'just' the 350 4bbl. (and not the 455)
http://www.amazon.com/Carter-Carbure.../dp/0931472113
The Carter is a great carb, quite sophisticated in it's design. Try this book for more info on tuning your carb. It provides lots of info on getting the best out of the carb.
Most carbs have multiple fuel/air circuits. The idle mixture is adjusted as above, but the mainjets are adjusted differently, as shown in this book.
