Old 06-09-2009, 04:49 PM
danshot danshot is offline
99 verse 95 Lesabre ignition parts
My 99 lesabre, custom, is missing here and there sometimes. I also own a 95 lesabre. Just wondering if anyone knows if some ignition parts from my 95 are interchangable with my 99. ie; coil packs, ignition module.
Old 06-09-2009, 06:10 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 99 verse 95 Lesabre ignition parts
They both use the same replacement ICM & coils. Have you changed the wires?
Old 06-10-2009, 07:35 AM
Haven't replaced wires or plugs yet. Seems to stumble a little only after it warms up. Kind of intermittently.
Old 06-10-2009, 08:42 PM
HotZ28's Avatar
AF Moderator Elite
I would change the wires & plugs first; how many miles on the plugs and are the wires original? You might also try a cooler thermostat for the summer and always use name brand gas like BP, Shell Texaco, or Chevron.
Old 06-29-2009, 02:38 PM
Changed wires and problem solved. Ohmed them out after and had just one bad wire. I'll keep the others for my other buick lasabre. Thanks for the help.
