Old 06-09-2009, 02:59 PM
Buzzed Buzzed is offline
2006 Grand Caravan A/C
I have a 2006 Grand Caravan. I may be imagining stuff but I think the front AC isn't blowing as cold and the rear AC. How can I check the System? Is this a problem that the GC's have?
Old 06-17-2009, 05:04 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 2006 Grand Caravan A/C
Put a thermometer at a front vent and a rear vent for a few minutes and compare. Don't know if there is an established limit but I'd say if they are within 5 deg I'd call it good.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 06-18-2009, 08:23 AM
It is way more than 5 degrees more like 15 to 20
Old 06-18-2009, 09:02 PM
iwannagofast iwannagofast is offline
The rear a/c evaporators are notorious to leak on these last model caravans.
you need an A/C machine to charge the system.this is something you might have to take to the shop.To replace the rear evaporator and recharge/leak check the system, you are probably getting charged around 3 hrs labor. (i believe its 2.3 hrs to replace, then what ever they charge you to recharge).
the part itself costs $350 if i remember correctly.
Old 06-18-2009, 09:06 PM
maybe in the old r-12 days? you'd be luck to get 25 deg out of those vents with r134.i usually see 25-30 with the car going down the road, 38-40 deg car sitting in the shop about 90 deg ambient.
Old 06-19-2009, 01:06 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
I was refering to a 5 degree difference between the air coming out of the rear vents and the air out of the front vents, certainly not a 5 degree reading from a single vent. Hell, we'd all be wearing parkas.
