Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 06-09-2009, 02:21 PM
wirewheel99 wirewheel99 is offline
transmission ID
Hi, I need help with a trans ID. It came out of Dr. Panoz AIV and we will be putting it and some other engine bits up for sale soon.
It is a Tremec and I think a T56 but not 100% sure.
On the tag it has:
YR33 700 3AA B0102
TSET 1386 AA 0323
Thanks for any and all help.
Best wishes
James
wirewheel
Old 06-09-2009, 10:02 PM
PanozDuke PanozDuke is offline
Re: transmission ID
James,
If it is a Tremec and a six speed, it's a T56. If it has 5 speeds, and hooked up to a 4.6 Cobra motor of the late 90's, it is probably the T45. If it came in a 5.0 car it is probably the T5. If it was swapped out from what came from Ford when the car was built, it could be any number of 3550/TKO variants through the 600. I don't know how to decode the numbers from the case, but you could probably get a definite answer from Tremec, including which gear ratios and input and output spline counts it has as there were options these models. That info will be important for any potential buyer.
Mike
Old 06-10-2009, 08:23 AM
eric1h eric1h is offline
Re: transmission ID
Some good info here
http://www.ttcautomotive.com/English/products/T-56.asp
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
