Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-09-2009, 02:21 PM
dagan06 dagan06 is offline
92 Died and won't start
was on the highway and it started missing. took an exit so i could get it to a gas station to look at it. was stopped at a light and it died when i went to take off and wouldn't start back up. i replaced the fuel filter still no luck. fuel pressure is good and injectors are clean. i'm thinking it may have jumped time or the timing chain broke. What's the easist way to check the timming chain if it broke? Where is the plug for the ECU to check the "Service Engine Soon" light. or anything other suggestions on what to check woudl be great.
Re: 92 Died and won't start
Its a 4WD 3.1 V6 manual trans
Old 06-09-2009, 02:44 PM
Scrapper Scrapper is offline
AF Premium User
if you got the distrbuter take cap off and turn it over and see if the rotor button is turning and if not it is your chain.
Old 06-09-2009, 03:47 PM
I'll try it when i get off work. How hard is the chain and gears to change on a 3.1. I've done it on an S10 Blazer with a 4.3 but i had plenty of room to work with
Old 06-10-2009, 09:02 AM
the rotor turned and there is no play in the pully. Does anyone know where the plug is for the ECU to test the service engine soon light
Old 06-10-2009, 11:27 AM
Cat Fuzz Cat Fuzz is offline
The computer isn't going to tell you anything. If you know you're getting fuel, the next step is to check for spark.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 06-11-2009, 08:56 AM
checked the spark and all is good i was able to check all 6 plugs and everything is fine.
Old 06-16-2009, 02:00 PM
took the throttle body off and found a rock under the main housing of the throttle body. runs just fine now. next challange is gonna be valve cover gaskets
