Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 06-09-2009, 02:54 PM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
Where is the ignition module located 96 CV ???
Hi Guys
Where in the world is the ignition module located on the 96 Vic. It's not on the driver side inner fender area like the older models. I've got a no spark issue on this car. I've replaced both coil packs, cam and crank sensor and still no spark. This car ran absolutely perfect and for no good reason just up and quit. It's been broke down for way too long and I'm just beating my brains out trying to figure it out. What am I missing ?
Mike aka JYD
Old 06-09-2009, 07:16 PM
rhandwor rhandwor is offline
Re: Where is the ignition module located 96 CV ???
Look on the side of the distributor. It takes a 7/32 deep socket or a special tool. I use a 12 volt test light if the coil negative blinks when trying to start look at the module. Advance or Auto Zone check free. If it doesn't blink replace the pickup in the side of the distributor. This requires a puller.
http://www.tooltopia.com/ THE415 Module KD3197
Old 06-09-2009, 07:58 PM
No distributor on this one, just coil packs.
Mike aka JYD
Old 06-09-2009, 08:57 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Are the wires broken under the front bumper cover? Look under the right headlight area where the wires cross the bumper. Possibly a brown wire or a green/red wire.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-09-2009, 09:41 PM
I was 10 years off if the wire is satisfactory check camshaft position sensor and crankshaft position sensor.
Old 06-10-2009, 09:01 AM
Hi guys here is what I've done so far.
It looks like I have a combo of two problems. I have a week/intermittent/no spark issue. And an intermittent fuel pressure problem. I have looked at all the wiring at and under both distribution boxes under hood, looked at all wiring under the bat tray. Replaced both coil packs, cam and crank sensor, spark plugs and wires, relays they are all working. I have power to the eec. On the fuel deal. some times I have pressure at the relief valve sometimes not. I replaced the injectors twice, filter, psi regulate. With the lines removed at the rail there is plenty of fuel flow. You can hear the pump running and it is pumping fuel. The only thing I haven't done is change the fuel pump. You know, the whole "week fuel psi thing" I seriously doubt that. But at this point I'm willing to try anything. I can do it without dropping the tank, so that's at least a bonus. getting those connectors to release is the worst part.
Mike aka JYD
Old 06-10-2009, 10:35 AM
I would check your ground wires a loose ground will cause all these types of problems.
Old 06-10-2009, 08:26 PM
I've checked all the ground wires I can see, they are tight with no corrosion. This is a nice clean southern car, not a rusty old nasty like I usually to work on. I also forgot to post previously that I replaced the computer as well.
Was discussing fuel pump pumping vs pump providing correct pressure with a friend today. He thinks the fuel pump is week and not pressuring up. I have another good pump I can try, so why not. Still disgusted with the car so I didn't touch it today, will try to swap the pump out tomorrow and see if I can get consistent fuel pressure back. I believe it will fire on that week spark, if it stays sparking at all. I will post results. I sure need to get this one running again, so I can move on the the next basket case non runner.
Mike aka JYD
Old 06-11-2009, 09:26 AM
Without a test gage its hard to say,my sons 97 Explorer went out and I took off the nozzle and sprayed starting fluid in and it started.
I would make up a pair of test leads and make a temporary ground and positive wire for the external pump. This will rule out wiring for the pump.
A bad pressure regulator will drop pressure. Pull the vacuum line if it has gas in it replace otherwise use a pair of vise grips and pinch off the return.
Some yards have a lift and other ones use a wrecker. These vehicles have a primer pump in the tank if you picked up the front if this pump is bad you could lose prime to the main pump. Normally they will run but not properly.
I imagine your using all used parts and its possible one of them is bad.
Old 06-11-2009, 09:55 AM
Make sure it has enough gas in the tank when picking it up with a wrecker you may uncover the pickup tube.
Old 06-12-2009, 07:31 AM
I tried starting it on spray and still nothing. I have 10 gallons of fresh gas in it. All of the parts that I am using are used, but they are from known runners. It's not the psi reg. since I tested it on another car and the other car runs fine off of the vics regulator. I was going to pinch off that return line and try that also, but it's got the hard plastic lines and don't want to break them. I am going to replace the pump today first thing and see what happens. I got a good one on the work bench right now. It worked fine on the car I took off of and it still runs when I put power to it, day before yesterday. All my power wires going to the pump are good, relay is good. The pump still runs and pumps fuel, it's just that week fuel psi thing. I am only changing the pumps to put that theory to rest. I sure hope that's the problem. I am running out of ideas here and the cars days are numbed at this point, I am fed up it.
Mike aka JYD
Old 06-12-2009, 08:11 AM
The pump could be bad but if this doesn't work did you look under the front bumper at the wires at this point?
Old 06-12-2009, 11:48 AM
Ok I replaced the pump this morning, fuel psi is stronger at the rail now. Things were pretty cruddy on the sending unit, just cleaning it up will help.
This damn thing still won't start. There was nothing wrong with the old fuel pump, just a bit varnished up and the rubber hose was rotted out. I believe the rubber hose was most of the problem. Now I just need to deal with this week/ no spark issue.
Yes I checked those wires under the battery tray. Pulled most of the wire casing off and I can't see any wires that look bad.
What about an ignition module on this one? Is there one? Any one? I sure would like to try swapping ignition modules.
Mike aka JYD
Old 06-12-2009, 05:16 PM
I swapped coil packs again today to my test car. The vics coil packs run the test car fine. The vics fuel psi regulator runs the test car fine.
Just for kicks I tried swapping out some ecu's. My test car will not run on the vics ecu and visa versa. The test car is a 95 Lincoln Town Car, so 1 year difference. I tried an ecu from a 98 LTC and the vic will spit and sputter and start to fire up, but just not quite start it. That ecu created some sort of life, that I haven't seen in a while. It definitely fired the engine several times. Well I am leaning towards the ECU as the cause of the problem. I don't know much about them, so I am thinking if I found one that was 1996 specific from another vic that might do the trick. Dealer wants 75 bucks to run diagnostic on it and they need the whole car. Like I am going to tow the car down there to have them tell me that the ecu is no good. It would be cheaper to buy one from a junk yard and hope for the best.
Mike aka JYD
Old 06-12-2009, 09:20 PM
Ground left rear of left front fender apron. Right fender apron right side of battery.Front of right fender apron. Rear of left front fender apron. Right cowl panel near door sill. Near #1 fuel injector. Center rear of trunk on support.
Fuel rail pressure sensor top of engine.
Use a test light and make sure the injectors have a signal. Also check for power to the coils. Use a gem clip in one terminal and light tip in other terminal.
