Old 06-09-2009, 02:47 AM
jetboy2004's Avatar
jetboy2004 jetboy2004 is offline
Cutting out windows into separate pieces
When you cut out the windows into separate pieces and attach them to the body individually, what do you use to cut and sand? Because I decided to go that route to avoid the ugly gap for the back glass, and it take FOREVER to cut the clear part and it takes a very long time for me to file it into shape. It drives me nuts when there's no progress after I file it with a pretty rough file for 5 minutes. A few pointers would be more than helpful. Thanks!
Old 06-09-2009, 04:15 AM
jano11 jano11 is offline
Re: Cutting out windows into separate pieces
Take your time, don't cut corners or you might be sorry at the end.
Old 06-09-2009, 05:17 AM
klutz_100's Avatar
Use p/e saws from Hasegawa, Crazy Modeler etc for the cutting. They make teh cleanest cuts you can possibly want.
Nail files and polishing sticks will bring the edges to perfection.
Old 06-09-2009, 02:51 PM
jetboy2004's Avatar
Thanks jano, I did take my time. It took me 2 hours to get the backglass to near perfect.
Old 06-09-2009, 02:56 PM
jetboy2004's Avatar
Thanks Kluts, I have the Crazy Modeler saw set B. It does make a nice clean cut. It just takes really long because the "glass" is 1mm thick. I cut the piece about 5mm bigger than the actual window size, and it takes forever to sand/file it down to the size of the window. However, I did find a way last night to make the process go a bit faster. I used an edge of a pair of scissors to shave off the extra part. It was a lot faster than filing. =]
Old 06-09-2009, 05:16 PM
You can cut closer than that to the actual window size, 2mm is more than enough for not ruining the part.
Old 06-09-2009, 05:30 PM
MidMazar's Avatar
MidMazar MidMazar is offline
Also what really works good or so i hear are those saws that cut foam. They get hot, up to a certain tempature and basically melt it. I've seen people on this board to that before, that creates the best edge. But i would test it out first.
Pe saws would be a good bet like stated before.
In Progress
