Old 06-08-2009, 02:52 PM
Boost1egt's Avatar
Boost1egt Boost1egt is offline
Exclamation 94 ga tranny problems
Its a 94 grand am , 2.3. Engine runs perfect, but when its put in drive it dies. I lifted one of the wheels off the ground and put the car in drive. the engine didn't die but the wheel spinned very fast, as if the transmission was in 3rd or 2nd gear. This problem does not happen in reverse nor neutral. I tried to retrieve the codes from the pcm, but the aldl connector its missing the terminal i have to ground. It has only 3 terminals. So would appreciate if you guys could help me with this too. I don't have the test box to test the tranny.
Old 06-08-2009, 04:38 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 94 ga tranny problems
Does it die with the engine cold and hot ?
If so it could be the TCC gone out.
On the connector, does it have any letters on it ?
If so ground B to A(pcm grnd). You know how to do it from there ?
1999 Grand Am SS 3.4 OHV
Old 06-09-2009, 08:06 AM
3100 3100 is offline
Banned
your obd 1 connector has 12 pins
F E D C B A
G - - - - M
so jump the last two terminals in the top row
