Old 06-08-2009, 10:36 AM
Canneth Canneth is offline
Tamiya TS17 gloss aluminium help!
Hi guys,
i am running into problem using Tamiya TS17 gloss aluminium, no matter how well i have mixed the paint, the paint just diffuse itself (please see picture), the paint is level and it is definitely not air bubbles. Any help?
BTW, i used tamiya surface primer + Tamiya TS30 Silver leaf as base paint + TS17 for top coat.. thanks in advance!!!
Old 06-08-2009, 10:53 AM
gasdriverca's Avatar
gasdriverca gasdriverca is offline
Send a message via Yahoo to gasdriverca
Re: Tamiya TS17 gloss aluminium help!
ouch!!!! that don't look too good but to me it looks as though the gloss aluminum(TS-17) reacted with the silver leaf(TS-30). Was the silver wet when you sprayed it?
Old 06-08-2009, 11:17 AM
MidMazar's Avatar
MidMazar MidMazar is offline
Also was it humid where you were spraying?
In Progress
Old 06-08-2009, 11:22 AM
mrsmorf mrsmorf is offline
Similar problem here:
http://www.automotiveforums.com/vbul...loss+aluminium
maybe this helps.............
Old 06-08-2009, 11:24 AM
ZoomZoomMX-5's Avatar
I know from decanting that Tamiya silver leaf doesn't like to be mixed with anything. I'd say you have a reaction from the gloss aluminum over silver leaf. You don't need to use silver leaf under gloss aluminum. Totally unnecessary step when used over gray primer. Gloss aluminum covers quite well.
My Fotki Album
Old 06-08-2009, 01:12 PM
JimboCO JimboCO is offline
I've seen this same thing when I've gotten too heavy-handed with spraying it on. Try lighter mist coats.
Old 06-08-2009, 09:00 PM
tuned.by.twenty's Avatar
tuned.by.twenty tuned.by.twenty is offline
AF Vendor-TBT's Owner
That's pretty severe.
My usual process for TS-17 is to spray a couple of light coats over grey primer. Nothing too wet, and no base coats. It works every time.
Old 06-08-2009, 10:35 PM
koksik's Avatar
koksik koksik is offline
Yes, try a first light coat of silver and of clear. If is too wet then both paint's get in reaction
Old 06-09-2009, 04:09 AM
xpeed's Avatar
xpeed xpeed is offline
I've had problems with the TS-17s as well. I just started putting on light coats each hour. About 5 coats and I get even layers.
Lexus LF-A Roadster Concept with my bodykit design
"Current Projects"
Nismo Kure GT-R - 0% Sileighty/Onevia - 35%/25%, MCR R34 GT-R - 10%, R34 JGTC Xanavi - 30%, JGTC Raybrig NSX - 0%, 2009/2011 WRX STi - 50%/0%, D1GP Kazama S15 - 55%, Toyota Celica - 2%, Calsonic Z Super GT - 0%, Calsonic R32 GT-R Race car - 5%, C-West RX-7 - 40%, Nismo 350Z 5%, Blitz Chaser - 90%.... a lot of unfinished work.
Old 06-09-2009, 05:36 AM
thanks for the valuable inputs everyone, i guess i will try again with light coats.
