Go Back   Automotive Forums Car Chat > Chevrolet > Chevelle
Old 06-07-2009, 09:01 PM
wulfie wulfie is offline
HO 454 into a 68 chevelle
Having problems with the stamped pan on a gm perf. HO 454 making contact with the crosmember on the drivers side. The motor mounts are in the right place and are correct. Any part # on something that will fit?
Old 06-08-2009, 01:18 PM
MrPbody MrPbody is offline
AF -Advisor
Re: HO 454 into a 68 chevelle
I don't have the number handy, but Chevelle uses a different pan on the big block than the other Chevy bodies. Check with Summit or Jeg's. Specify "Chevelle".
Jim
Old 06-08-2009, 07:32 PM
mdcamaro mdcamaro is offline
If the car was not an original big block you need to change the frame mounts.
396, 427, 454 all use the same motor mounts, frame mounts and oil pan.
Check Year One.
Old 06-10-2009, 08:34 AM
AF -Advisor
MD,
Chevelle uses a specific oil pan to clear the crossmember. It's not a BBC thing, it's a Chevelle thing. This is not an opinion. Chevelle pans "fit" other cars. Other pans do not fit Chevelle.
Jim
