Old 06-07-2009, 01:25 PM
crazyduetoiowa crazyduetoiowa is offline
Send a message via AIM to crazyduetoiowa Send a message via Yahoo to crazyduetoiowa
2000 Cavalier Vent Flow Problem
I have a 2000 z24 cavalier with a 2.4ltr. The air blows through the vents at the face and feet on mainly all settings. It will spit a small amout out the defrost. The fan speeds all work correctly as I put a new resistor in last year. Can anyone save my back before i go digging under the dash? Thanks Derek.
Old 06-08-2009, 07:07 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 2000 Cavalier Vent Flow Problem
The controls are cable operated, most likely the cable fell off one end. Most common is the end at the HVAC box.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
