Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 06-06-2009, 11:48 PM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Got a bunch done today w/ my father... new tach, new fire system, hood pins etc.
Towed the car down to Greensboro, NC to it's new home in my father's garage Friday night. He finally has a place to park our car trailer and he's only 50 min from VIR so it makes sense to keep it here. Plus it frees up my garage for my new Jetski
Finished the hoodpin setup, but forgot to take pics of the hood on. Installed a new Autometer 5" analog tach, a manual fan switch, and a new Firefox fire system.
Hood won't be going anywhere now... will snap a pic of the pretty side tomorrow. I used allen headed bolts w/ lock nuts and washers similar to what the rest of the car uses. Got it all at Fastenal.
The tach was the big project... and I'm very happy we did it. I ended up pillaging the stock EFI wiring harness remnants from our carb swap for wires and more importantly a plug so I could make a quick disconnect for the tach and remove the dash easily. Took a long time getting it just right and soldering the connections, but it wall works!
All wire loomed and pretty after verifying it works...
Converted my interior wiper motor wire/switch to a manual fan switch
New Firefox setup installed... was able to shorten the previous bottle's hold-downs to fit the narrower firefox. Also was able to ue the existing nozzles, but installed a new pull cord. Nice setup... but no instructions, but I figured it out.
The new lexan windshield didn't come in on Friday for me to help install it, but I have to say taking the glass out made it 1000x easier to work on the car.
G'night!
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Old 06-07-2009, 09:20 AM
eric1h eric1h is offline
Re: Got a bunch done today w/ my father... new tach, new fire system, hood pins etc.
nice.... and dusty! ;-)
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 06-07-2009, 10:27 AM
panozracing's Avatar
panozracing panozracing is offline
Originally Posted by Cobra4B View Post
HOLY HUGE HARDWARE BATMAN!!!
what kind of weight is that....you are using those on the entire bodywork? What happened to the nice little SS button head cap screws (allen heads) with flange nuts that PAD uses? They use a 3/16" drill and 1/8th allen wrench....
yours look HUGE! There is a 100 of those things on our car. Did you change them all out? Maybe is the scale in the photo
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 06-07-2009, 03:19 PM
Cobra4B's Avatar
Car always looks way dirtier w/ a camera flash than it really is for some reason. I wiped everything down with windex while I had the glass out and vaccumed it all up
Actually what you're seeing is the washer under the nut on the underside of the hood to spread the clamp load. The hardware is the exact same stuff Panoz uses, but with a slightly coarser thread... same size allen head and same size 7/16" socket to take them off. I took on to Fastenal with me to match it.
More work done today... we cleaned the car up, mounted the R6s and did all the track prep to it. Also added some fresh plug wire protectors etc.
R6 scrubs - 275/40/17s
New Plug wire boots
Daytime shot of the new tach and firebottle
Hoodpins done
Was about to wash it and put a coat of Rejex on the front end, but have to head back to Va Beach.
Car sharing it's new home w/ my father's LeMans Edition Z16 Z06 Corvette (which is for sale BTW).
Brian B.
Old 06-07-2009, 04:26 PM
Nice work.....Looks great!
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 06-07-2009, 04:32 PM
Dawgfan Dawgfan is offline
Cobra, what kind of engine are we looking at theie?
Old 06-07-2009, 07:51 PM
feqrags feqrags is offline
really nice car! the headers look great and nice wiring job. Bill (wish I was as close to tracks as you guys are
Old 06-07-2009, 08:42 PM
it's a carb'd 5.0
