Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 06-06-2009, 03:23 PM
orange_bullet orange_bullet is offline
Talking 90 iroc oil leak needs help
on my 90 iroc i have a 350 and i found my oil leak. the leak is on the passenger side of the oil pan the oil is comming threw the bolts on the back of the pan. i would rather not take the pan out cause that goes with having to take out the transmition. have info would be great.
Old 06-06-2009, 04:26 PM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
Re: 90 iroc oil leak needs help
drain the oil take all the bolts out of the pan so you can lower it don't have to completely remove it from the car clean it and any gasket surface the best you can use break cleaner let every thing dry the do your best to run a bead of silicone glue around the flange of the pan wait about 15 minutes and put the bolts back in just tight enough to ooze the the glue out a little bit now wait about an hour and tighten the bolts just tight don't over tighten them make sure you drain the pan of any cleaner and run a quart of oil through the motor with the drain plug out to clean out any debris that may have gotten in the pan now replace the oil and do your thing but the next day check the bolts to be sure they are still tight
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
