Old 06-06-2009, 11:27 AM
alen181 alen181 is offline
thermostat on 02 olds intriqe
i just had to put a new water pump on my car i got a bosh the thermostat i got from rockauto acdelco part 1510575 we it came it hade awahler stamp on it i pit it on ok i just to know if that one hase the 4 slots on the bottom plate as i allredy put on car . alen
Old 06-06-2009, 12:06 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: thermostat on 02 olds intriqe
Yeah it should be just fine, mine is exactly the same thing youve got and its been going strong for a bit now. I think the old one said the same thing on mine.
I dont know if Wahler is who makes them for AcDelco or how that works exactly. But itll be fine.
I should add, that after replacing the water pump and thermostat, if you havent already you should bleed the system. The bleeder valve is located on the passenger side of the radiator at the top.
You can also leave the cap on the overflow tank a little looser, that should help the system bleed itself.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
