Old 06-05-2009, 04:49 PM
Gordon325 Gordon325 is offline
Crackbox Breather?
Tube coming from a black box in front of engine block connected to a tube from my air filter looked it up said its called a "crank box breather"
#1 what does this do?
#2 is it bad if there is gas (or oil) in the tubes that conect to my air filter? and if so is this cause from this breather?
#3 with a crank box breather how do i install
a cold air intake?
Please help i am so confused:
Yes there is fluid in my air filter tubes (smells like gas) only thought is its coming from that crank box breather tube?
-Gordon
Old 06-06-2009, 01:51 PM
Re: Crackbox Breather?
never mind i think i figured it out,
#1 crank box breather bring air from pressure in engine back through the air filter system from oil/air separator
#2 Cracked vacuum hose (VERY CRACKED) would as i see it cause bad pressure causing burnt gas or oil to seap through my crank box breather.
#3 a (non-cheap) cold air intake setup will have proper connections for a crank box breather tube.
thanks every one lol jk!!
you can close if u want.
