Old 06-04-2009, 05:16 PM
vr4choke's Avatar
vr4choke vr4choke is offline
Send a message via AIM to vr4choke Send a message via MSN to vr4choke
SRS light bulb pull
i need to get my SRS light off so i can pass inspection. it asnt a problem in cali, but for some reason the hawaiins give a dam. so how do i get to the bulb? please dont say dash teardown
NEVERMIND
Old 06-04-2009, 07:43 PM
Girly VR-4 Girly VR-4 is offline
Re: SRS light bulb pull
go to a dealership or any local shop that has a snap-on scan tool, and they can reset your code and get rid of the light
www.groundzeroperformance.com
www.3swarehouse.com
1991 Stealth R/T Twin Turbo... sitting...
1996 Orchid Pearl Stealth R/T.... daily driver duty, 275k+ miles and counting!
1995 3000GT Spyder SL... being modified...
Old 06-04-2009, 09:26 PM
vr4choke's Avatar
too late. lol already got the bulb out. thanks tho
Old 06-05-2009, 12:56 PM
91STT 91STT is offline
3SNJ Pres
Sometimes the SRS light comes after the battery is disconnected and reconnected when there is nothing wrong with the system. If you are sure there is nothing wrong, the light can be reset by turning the ignition on and off ten times within like ten seconds.
1991 Stealth R/T TT
It looks stock, so it must be.
Old 06-05-2009, 03:04 PM
raisenop3's Avatar
raisenop3 raisenop3 is offline
That's easy enough - I'm having the same problem with mine (as I posted somewhere else on this board). I should have looked here first. I hope it works!! Thanks!
UPDATE - the on/off with the ignition 10 times didn't work with my Eclipse, so maybe it's just the 3000GT.
Old 06-05-2009, 08:10 PM
taking the bulb out, doesn't get rid of the error code.... just saying...
www.3swarehouse.com
Old 06-06-2009, 09:19 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
And another thing, some places wont inspect it if they get no light at all, so pulling the bulb might not get you through either.
Old 06-08-2009, 10:47 PM
vr4choke's Avatar
i dont really care about the error message, i just needed it to pass inspection, which it did. as for what you said stealthee i guess they just dont give a dam. hooray for carefree hawaiins!
